Costing - Decimal point limitation
Vadet
Go to solution Solved by Natali,
Hi!
Is it possible to increase the number of decimal points for the cost of each unit of an item? Currently, it is only two decimal points, the minimum of which that we can enter is 0.01. But we have a lot of purchases much less than that. Is it possible to increase it to at least 5 decimal places (example: 0.00001)? This system limitation has a huge effect on our food costing.
Thank you very much.
Hi!
It is not possible in Loyverse to have more than 2 decimals. Maybe it will be fine to use smaller unit so cost will be smaller and will require less decimals
  • 2 months later...
hello,
my shop are still testing this software, but same situation like this article, it really makes some people confused to read.
It would be very convenient if we have an option to just "turn on/ off display the decimal", yes, we don't need the function "change" but "display".
Thank you for your suggestion!
As we are always working on improving our product to make our customers happy and satisfied, to provide the best service, I will be happy to pass it as a feature suggestion to the development team. However, please note that the suggestions may not be always implemented fully.
