Is it possible to add an option to the products so that a shopping list can be printed per supplier
Dear people, I have introduced different products from different suppliers.
Is it possible to add an option to the products so that a shopping list can be printed per supplier.
Hello Assa-Manado!
Am I correct, you want to see the list of items from supplier? do you need only to be able to see the list with available stock? or you want to be able to fill up the Purchase order with low stock items from particular supplier or all the items? because we have this feature already! It is Autofill option in Purchase order.
Please, check here for more information https://help.loyverse.com/help/autofill-items-purchase-order
Thank you Christine i will loking for it.
I mean if I want to order products from a certain supplier I can only print a list of them.
I will look at your response.
  • 9 months later...
You can order all items from a certain supplier with an autofill option in a Purchase order
