POS printer from Aliexpress
Go to solution Solved by doko,
Maybe yes or maybe not, it's better to use the recommended list of printers
That meens cost of €300 more. 😞
Try looking in this list for a cheap printer. Since there is no guarantee that the printer XP-58IIH works with Loyverse POS
On 2/6/2020 at 10:21 PM, Assa-Manado said:
I'm using the same printer and it prints find. but having problem with the alignment though.
You can buy an old Epson printer, even with the Centronics interface, and just buy the adapter on Aliexpress.
So it will be cheaper and more reliable than using a Chinese printer.
I bought this printer. Linked by bluetooth and linked to a cash drawer. Configured and everything works perfectly.
https://www.aliexpress.com/item/4000195456239.html?spm=a2g0o.productlist.0.0.630f27b4OjZvU6&algo_pvid=83502174-dfa3-42c6-9b87-74eccf6bf3df&algo_expid=83502174-dfa3-42c6-9b87-74eccf6bf3df-5&btsid=1c543ab4-e759-4153-8564-834a7b6127b4&ws_ab_test=searchweb0_0,searchweb201602_3,searchweb201603_53
Product is guaranteed for Loyverse, even a Loyverse download link with the product.
