cherry314159 Posted December 16, 2019 Posted December 16, 2019 I would like to use KDS on an Xiaomi Mi Box S Android TV. Unfortunately, KDS is not available for Android TV. Note that another POS is available. Please mark KDS as compatible.
Solution Andy Posted May 25, 2020 Solution Posted May 25, 2020 Hello. You can download the Loyverse KDS app here and run it on the Android TV.
jag136655 Posted August 3, 2020 Posted August 3, 2020 Hi I want to know can we use KDS on aandriod tv, i tried couple of andriod tvs , but KDS app not coming on play store.. Can any one help, how to get KDS on big screen of andriod tv..Please ThxJAg
CafeBOBA Posted January 18, 2021 Posted January 18, 2021 Hi Andy Can you tell me how to run Loyverse-KDS-1.04.apk on the android TV? Thank you very much.
disneymode Posted December 13, 2021 Posted December 13, 2021 i run my KDS on mibox-s android tv msg me, i can teach you to configure it
disneymode Posted August 25, 2024 Posted August 25, 2024 1.) download and install Fx File explorer on mibox or any android tv (google) 2.) set permission on FX file explorer to full access 3.) get a thumb drive and download kds apk and atv apk get the free ones 4.) insert thumb drive in the usb port of mibox/android tv 5.) on your mibox / android tv run the app FX file explorer, then nagivate to media ,locate and install kds apk and atv apk, 6.) after installing both apk, go to home of mibox/android and run the app ATV, then locate and run Loyverse Kds. 7.) login your credentials.. drop me message if its working.. sorry for long reply, been busy 1
Yasu Posted September 6, 2024 Posted September 6, 2024 On 8/25/2024 at 5:12 AM, disneymode said: 1.) download and install Fx File explorer on mibox or any android tv (google) 2.) set permission on FX file explorer to full access 3.) get a thumb drive and download kds apk and atv apk get the free ones 4.) insert thumb drive in the usb port of mibox/android tv 5.) on your mibox / android tv run the app FX file explorer, then nagivate to media ,locate and install kds apk and atv apk, 6.) after installing both apk, go to home of mibox/android and run the app ATV, then locate and run Loyverse Kds. 7.) login your credentials.. drop me message if its working.. sorry for long reply, been busy Thank you for your answer!
