KBSS Posted November 7, 2019 Posted November 7, 2019 I was planning to run the Loyverse POS on iOS, and then have 2 different KDS, one using iOS and the other using Android, and I'm not sure which one will run the CDS. I'm using a mix because that is what we have available and it is for a not-for-profit fundraising event. Does anyone know if the different operating systems will play nicely together to run a Loyverse system? I assume so but was hoping to hear from anyone that has done it successfully.
Solution Natali Posted November 8, 2019 Solution Posted November 8, 2019 Hi Bloke! Yes, it is indeed working fine as the system. Just they still have a few less options for Android compare with iOS devices. For example, you can resend order to KDS from iOS but not from Android. 1
