How can I protect my business from employee fraud?
Go to solution Solved by Iscander,
If my employee wants to hide some sales from me and take some part of the proceeds, he can just turn off Wi-Fi and then clear the data in the settings.
How to prevent this whole situation?
I think it is impossible to prevent this situation, but you can give you employee access through PIN. And then change the PIN. If he will delete date the POS will be logged out. And he can't enter the system without a new PIN. After this, if your employee often say you that system is logged out and you doubt his honesty you can check through camera his action.
