How to update Loyverse POS System?
Go to solution Solved by Guest lord,
I have an old version of Loyverse POS on Android, I can’t update it. The update message does not arrive on the smartphone. What should I do? Any ideas? 🤔
Use the Play Store app on your smartphone to update Loyverse
Select My apps & games
 and update the application you need
  • 5 years later...
