Which label printer do you recommend?
CWL
Go to solution Solved by Nile,
  • 3 months later...
I want to print labels for the items I'm selling, and I'm wondering which label printer works with Loyverse. A printer that prints on adhesive paper that I can stick on items.
thank you
  • 1 month later...
Hello ,
As tech pro, I know well on Loyverse POS application.
So far, you can only print label for items from loyverse Back Office on PC(Windows) or Mac via USB label printers ( https://loyverse.com/hardware).
If it is not convenient , you could consider to print item label with our mobile mini label printer ER-5801,
but currently you could only install our simple Android label app , and edit the item label content( price/item name, barcode.....) , and then print it out easily.
( You could watch the following youtube video for the details of our label printer)
In future, maybe we could work with Loyverse POS development team to combine this function in Loyverse POS App,user can easily to print item label just from Android Loyverse POS App and iOS Loyverse POS App, it would be much more convenient.  We will contact with Loyverse development to see if this can be put on schedule.
