Carlos Os Posted August 2, 2019 Posted August 2, 2019 I have 2 printers Epson TM-T20ii (USB) and I will use and ipad as POS and a tablet andriod as Kitchen screen in my cafe. As I read here it is not possible to set up a USB printer to iOS, my question is if its possible to connect by USB two printers to my android tablet and print receives from the iPad?
Solution Andy Posted August 2, 2019 Solution Posted August 2, 2019 It is possible to connect the USB printers to iOS devices, but only from the supported printers list https://help.loyverse.com/help/supported-printers Unfortunately your printer Epson TM-T20ii (USB) is not in the supported printers list for iOS devices and will not work with them. You may try to connect this printer to Android devices, but you cannot print on Android from the iOS POS.
Carlos Os Posted August 2, 2019 Author Posted August 2, 2019 Andy, And what if y tried to connect the printer by a P-Link TL-PS310U, so I can set up like if it was Ethernet
Andy Posted August 6, 2019 Posted August 6, 2019 Unfortunately you cannot connect this printer to the WiFi router via USB. It will not be recognized as Ethernet printer.
