How to manage tables in Loyverse POS?
Go to solution Solved by Robert,
How to manage tables in Loyverse POS? It is very necessary feature !
If you use Loyverse POS in iOS now you can use the "Predefined Open Tickets" feature to set a list of tables in your pos. This way it becomes much easier to assign tables to every new order. This is how it looks in the app:
So everytime you save an open ticket the list will pop up, and you can select one of them.
Here is the manual to learn how to do it:
https://help.loyverse.com/help/how-use-predefined-open-tickets
You have to use 'Open tickets' option in Loyverse POS. Open tickets allow you to create, edit, and save an order, before completing a sale.
How to use open tickets here: Open Tickets https://help.loyverse.com/help/open-tickets.
You can name your tickets as tables. For example "Table 1", "Table2",... Or just "1", "2" etc.
Currently there is no table options available, however when creating a ticket you can name it T1 for table 1 for instance this helps to tell them apart. I agree though that it would be a nice feature to have for alarge restaurants.
