How do I connect Loyverse to a munbyn printer
Go to solution Solved by Donald,
  • 2 months later...
Loyverse is compatible with thermal printers that support ESC/POS commands.
To set up a printer with Loyverse POS open the app, go to settings, add a printer, and select "other model" as your printer model. If you use Android, you can choose between Ethernet, bluetooth or USB interface. Choose the right interface and proceed to connec the printer.
If you use iOS you can only chose Ethernet as the interface.
In general it's a simple process.
Here is more information from the Loyverse help ceter: https://help.loyverse.com/help/how-set-other-printers-loyverse-pos
