Gizsmo Posted September 25, 2018 Posted September 25, 2018 How to connect the printer using Bluetooth on IOS
Solution Reinaldo Posted November 30, 2018 Solution Posted November 30, 2018 There is a list of the compatible Bluetooth printers for iOS, you must use one of them because other models are not supported. You can see the recommended printers on the web: https://loyverse.com/hardware And this is a set up guide that you can find on the help center: How to Set Up Bluetooth Receipt Printer with Loyverse POS If you want to look for other options I recommend you to get an Ethernet printer, personally I think Wi-fi connectivity is more reliable than Bluetooth and Loyverse allows you to connect other models as long as they support ESC/POS commands. Also, please watch the video below:
