cafe Posted July 19, 2018 Posted July 19, 2018 How to setup a WiFi printer? Apparently, the IP address was programmed into it already by the reseller for me.
Solution Andrew de Freitas Posted July 24, 2018 Solution Posted July 24, 2018 You will need to know that IP address that was set. It has to be in the same subnet (IP Range) as your network otherwise it won't be able to communicate with the rest of the equipment. What brand is it? Some manufacturers have an app you can download to find and reconfigure the printers.
