Solution Andy Posted December 29, 2017 Solution Posted December 29, 2017 Unfortunately, iOS devices do not support the USB by itself. So, there is no way to connect the USB printer to the iPad.
Europelle SG Posted April 9, 2018 Posted April 9, 2018 I have a bluetooth printer that cannot be connected on iOS. I can only think of 2 solutions. First is to connect the printer directly to iPad via OTG cable. Second is to connect USB printer to AirPrint server and point iPad to it. Can anyone advise on this? I really need help on this!! :(
Gabbi Posted April 9, 2018 Posted April 9, 2018 Hello! USB printers don't work with iOS devices, unfortunately. You can use a printer from those recommended on website for iOS. If you want to use another printer then you should choose Ethernet interface.
Blinken Posted June 22, 2022 Posted June 22, 2022 I found that there are a couple of USB printers officially supported on iOS! Star TSP143IIIU (USB) Star mC-Print3 (USB, Bluetooth, Ethernet) How to Set Up a USB Printer with an iOS Devicehttps://help.loyverse.com/help/how-set-usb-printer-ios-device
