How to add customer's gift card?
Go to solution Solved by BoutiqueCarmesi,
Hello, does someone know how to add a gift card to a customer?
Hi, in our store we gave gift cards to some of our customers, and to add the gift card to the customer what we do is the following:
1. In the customer section, we select the customer we want to add to the gift card.
2. We fill the “Customer code” field, with the numbers from the gift card, by doing this we can use this code to add the gift card when the customer purchases because it is saved in their profile
3. Then we add the value of the gift card to the profile of the customer in the “Edit points of balance” so the customer can use these points to buy
I hope this can help you
Edited by BoutiqueCarmesi
  • Thanks 1
