George23 Posted April 26, 2023 Posted April 26, 2023 Hello, Can anybody help me to connect a Star TSP 100 printer to an Android device by using the USB port with OTG. Or is it only possible by ethernet connection? Thank you very much
Smoothie Posted April 28, 2025 Posted April 28, 2025 On 4/26/2023 at 12:13 PM, George23 said: Hello, Can anybody help me to connect a Star TSP 100 printer to an Android device by using the USB port with OTG. Or is it only possible by ethernet connection? Thank you very much Anyone knows?
Yasuaki Posted April 29, 2025 Posted April 29, 2025 Hello. Unfortunately, Star TSP 100 printer (USB) is not supported in Loyverse POS on Android.
Smoothie Posted April 29, 2025 Posted April 29, 2025 4 hours ago, Yasu said: Hello. Unfortunately, Star TSP 100 printer (USB) is not supported in Loyverse POS on Android. Thank you. Bad news for me but at least I know I am not as dumb as I was feeling not being able to get them to work. Can you recommend a reliable cheap USB printer that I can use in it's place with an android tablet? And does anyone want an unused star tsp 100 to buy?
