Settling up a cashless payment system with unique voucher codes
Hi there, we would like to use Loyverse in a commercial cashless canteen setting. Employees collect their meals using a unique voucher code on a daily basis. Approximately 28 ooo unique voucher codes will be used only once by an employee each month and then we'll generate daily, weekly & monthly reports of the number of vouchers used. Basically, the entire setup is cashless and we will invoice the client based on the number of vouchers redeemed. We are able to generate unique QR codes that can be printed on each physical voucher and scanned upon the customer's redemption but need assistance with linking these to the Loyverse system so that it can pick up that 100% of the meal order is discounted and the voucher has not yet expired. Assume that all meals are the exact same price so each voucher value is the same.
Unfortunately, we do not have a special feature to generate and track voucher codes. As an alternative solution, you can use Loyverse loyalty system:
How to Set Up a Customer Loyalty Program
https://help.loyverse.com/help/how-customer-loyalty-program
How to Redeem Customer Points for a Discount
https://help.loyverse.com/help/points-discounts
Or you can contact our integration partners from Loyverse Marketplace if they can propose you something more suitable for voucher codes management:
BrandWallet
https://loyverse.com/marketplace/brand-wallet
Zapier
https://loyverse.com/marketplace/zapier
Make (formerly Integromat)
https://loyverse.com/marketplace/integromat
Zoho Flow
https://loyverse.com/marketplace/zoho-flow
Read more
