Credit Card Reader on mobile Android POS device
To enable seamless, closed-loop payments I'm looking for a way to accept credit card payments directly on an android POS device.
The documentation ( https://loyverse.com/sumup ) shows how to use the Loyverse POS + SumUp card reader but I'd like to use the built-in card reader of the android POS device instead. Payment could go through SumUp or another provider. Is this possible? Is there any documentation I'm missing?
Thanks!
Loyverse will not be able to integrate and connect with the built-in card reader provided by the Android POS device. The supported card reader for Sumup is SumUp Air 1E000 (Bluetooth). However, what I can do suggest is that you can still use that built-in card reader without having it integrated/connected to Loyverse POS App as we have the flexibility in doing so. For this, you can check out this guide provided about how accepting credit cards without integration works: https://help.loyverse.com/help/how-work-credit-card-payments
Read more
