I have noticed two items that are having visibility issues on Loyverse
Why do some items do not appear in the menu?
Some items might not appear on POS because of the checkbox 'The item is available for sale' is inactive in 'Edit Item' card in Backoffice. Maybe due to this reason.
  • 4 years later...
I have noticed two items that are having visibility issues on loyverse. I can view them on the app when I'm sending receipts to customers. The quantity also reduces afterwards. However when I go to the backend, I can't view the quantity once I open the item. I cant see the codes, quantity available in other stores etc. I don't want to delete the item and add it back because the code has been used to send the items to different places already. I've attached Images of the backoffice and the app for one of the items.
Might I perhaps suggest that in your Loyverse POS App, try to click on the "Sync" button that can be found in the Sales Screen under the three dotted button and check to see if this helps to update the information onto the Back Office?
In any case, I'll have this be checked by our team as well. Thank you for notifying us.
Also, could I ask in which browser did you checked this item in your Back Office? Did you checked this in a mobile/tablet device or did you check this iny our PC? If so, which browser did you use to open your Back Office?
I’ve tried the sync button but to no avail. I use a chrome on my chrome book. Ive also checked with mobile. Thanks for the prompt response
May I ask what is the Google Chrome version that you are using please?
