Jrivera Posted November 2, 2017 Share Posted November 2, 2017 Is my SM-T300i mobile bluetooth printer compatible with Loyverse on my IOS device? Link to comment Share on other sites More sharing options...
Solution Reinaldo Posted November 2, 2017 Solution Share Posted November 2, 2017 At first I would say it's not compatible. Loyverse POS for iOS is a little bit limited regarding bluetooth printers. You can only use those from the recommended printer list, which would be the Star TSP654IIBl (Bluetooth) and the Star mPOP. About your mobile printer, if you already own it, you could actually try to set it up, using the TSP654IIBl (Bluetooth) as printer model in the printer settings. Who knows, it could work, but the chances are not high. Hey, if you have results let us all know about it, whether it worked or not, it would be good for everybody to know. Link to comment Share on other sites More sharing options...
