GhostHitman007 Posted October 20, 2021 Posted October 20, 2021 I have tested many TV Box for Android POS terminal. Tested on: Mi Box S, MX10 Pro, MXQ Pro, Tanix TX6s, Tanix TX3 Max *USB Hubs works. *Mouse & keyboards works. *POS printers works. *Cash Drawers works. *CDS works. All those TV Box worked perfectly. But, only the barcode scanner doesn't work. Why you should use TV Box for POS? Because, to save money. For example, right now. Mi Box S is only 35 USD where a desktop Sunmi devices are over 600 USD.
Andy Posted October 21, 2021 Posted October 21, 2021 Hello. We appreciate your effort to test Loyverse POS on the Android TV box. There are two ways to connect the barcode scanner to the Android device: via Bluetooth and USB. Which one have you tried? Maybe you can try another one? 1
InovasiSMKTMA Posted June 30, 2022 Posted June 30, 2022 On 10/20/2021 at 7:29 PM, GhostHitman007 said: I have tested many TV Box for Android POS terminal. Tested on: Mi Box S, MX10 Pro, MXQ Pro, Tanix TX6s, Tanix TX3 Max *USB Hubs works. *Mouse & keyboards works. *POS printers works. *Cash Drawers works. *CDS works. All those TV Box worked perfectly. But, only the barcode scanner doesn't work. Why you should use TV Box for POS? Because, to save money. For example, right now. Mi Box S is only 35 USD where a desktop Sunmi devices are over 600 USD. Hi. Please try on Mx10 Pro. Then Enable usb debugging in the developer option and the change USB mode to Media Transfer File MTP to make it work. TQ
Tet Posted July 16, 2022 Posted July 16, 2022 same until now no update on how barcode scanner works in tv box
