Can I pay only for 1 store for Advanced Inventory? (Out of 3 stores)
Is it possible to bill the advanced Inventory module separately from the other stores I've created?
I have 3 stores and they are using the Sales modules; but for the Advanced Inventory Module I want to use it for 1 store only.
Hi Fab! Unfortunately Advanced Inventory subscription is applied for all existing stores. You cannot apply the Advanced Inventory subscription only for certain store.
when I click subscribe, it automatically calculates the rate for all 3 of my locations but I wanna use this option only in one location. How can I do that? It also does not give me the free trial option.
thanks,
Phil
Regarding trial, your trial is already finished/
If you would like to pay only for 1 store, you need to delete rest of stores. Unfortunately if you have 3 stores, you cannot pay only for 1 store.
I would suggest you create a separate Loyverse account for the store you want to use the Advanced Inventory subscription.
