Andy Posted April 5, 2021 Posted April 5, 2021 Hello. Unfortunately there is no possibilty to connect printer via serial port to Loyverse. Loyverse communicates with printer only via Ethernet, Bluetooth and USB ports.
Gobong Posted April 5, 2021 Author Posted April 5, 2021 Will there be updates soon to make this possible?
MarkSVH Posted March 20, 2024 Posted March 20, 2024 I am keen to find out if a serial printer becomes possible.
jpno5 Posted July 9, 2024 Posted July 9, 2024 You can use a serial printer on the citaq with citaq print proxy at citaqprintproxy.com citaq.co.uk
Apower Posted March 15, 2025 Posted March 15, 2025 El 9/7/2024 a las 2:02, jpno5 dijo: Puede usar una impresora serie en el citaq con el proxy de impresión citaq en citaqprintproxy.com citaq.co.uk Cuando me meto en la página, me dice que tengo que pagar 18 €. Con esto me aseguro de que la impresora funcione. ????
