Enable / Disable products
Go to solution Solved by ink,
You can switch off the checkbox 'The item is available for sale' and the item will not show in the POS.available-for-sale.thumb.png.5e29a39426ac9285153517536a1f7457.png
I get that, but that's the product view, not the list view.... so you can select x products and enable them in one action click from the list view.
It is not possible to do that at the moment (choosing sales availability in a bulk), but you can export and import your items, in the exported file you can select which item is available for sale and which item easily and then upload the file again
Please refer to the below link
Exporting and Importing Items
That’s what I’ve been doing for the last weeks but Re-importing sometimes creates issues.
