marshanite Posted November 24, 2020 Posted November 24, 2020 I've just input all my items into my epos and realised that my SKU's don't match my suppliers. I've tested changing one item to my suppliers but this has brought up problems in the fact that it doesn't delete the original item with the original SKU. Is there a work around for this, otherwise its a pain having to transpose my SKU's with my suppliers. Thanks in advance.
Solution Amirah Posted November 30, 2020 Solution Posted November 30, 2020 You will need to change them manually from the back office directly, exporting the items in a CSV file and then editing the SKU will not be possible as the system will prompt you that there are other items with the same Handle, when changing the handles, it will create completely new items accordingly
