Ivanbio Posted October 14, 2020 Posted October 14, 2020 I want to associate a barcode to a discount in order to scan the barcode and automatically get the discount, is it possible?
Solution Amirah Posted October 15, 2020 Solution Posted October 15, 2020 We do not have such a feature at the moment, however, you can name a discount with the barcode And then on the POS, while you have a barcode scanner connected, please tap on the search field From there you can scan the barcode of the discount and it will appear for you to choose 1 1
