RPWunterweex Posted April 5, 2020 Posted April 5, 2020 All my items are unique, that means for me that I can use the unique barcode as well to fill the SKU. Is that possible? Why would I prefer this procedure? For nearly automatical handling I do not want to download the whole itemlist, only to change some single items or add some single items. As far as I understand the process it seems to be easier to export only the modified items from my ERP (mostly price, sometimes weight) to a CSV/spreadsheet for the upload. I suppose the rest of the items remains in the item-list. Is this right?
Solution Amirah Posted April 6, 2020 Solution Posted April 6, 2020 It is possible to have the SKU and barcode for an item identical, the system will allow you to make such modifications. It is not possible to delete items using a CSV file, so adding/modifying some item using import function will not delete existing items on your list
