Nile Posted November 6, 2019 Posted November 6, 2019 Can I set a minimum number of loyalty points before my customers can use their points? For example, 50 points before customers can redeem their points.
Solution Femi Posted November 6, 2019 Solution Posted November 6, 2019 Unfortunately, that is not possible at the moment but alternatively, you can always check right in the POS app before redeeming. If perhaps the point balance isn't up to your minimum loyalty point, you will see it right there before charging.
