How to track items?
Go to solution Solved by Natali,
How to I add and keep track of items I buy in packs but sell as both single units and as packs?
Hi AlexZ!
In Loyverse system is possible to create a Composite Item and sell with it items by boxes. In such a case, the Item and The Composite item both will have the same stock of Item.
But it is not possible to buy Item by boxes and transmit the number of items in boxes into the stock of Item. So manual calculations are needed in this case.
Here is the link for an explanation about the Composite item:
https://help.loyverse.com/help/how-create-composite-item
I hope my reply will be helpful to you!
  • Thanks 1
