Can i connect two bluetooth device(barcode and printer) at a single time with Ipad
Go to solution Solved by Fer,
Can I connect two Bluetooth devices (barcode and printer) at a single time with Ipad
Yes, there shouldn't be any problem. It's important to point out that with iPad Loyverse is only compatible with the Socket Mobile CHS 7Ci (Bluetooth) and Socket Mobile CHS 7Qi (Bluetooth), which are the devices you can find on the Loyverse website: https://loyverse.com/hardware
