James Lavud Posted September 16, 2017 Posted September 16, 2017 My device is broken, how do I copy items to another device?
GadgetForLess Posted September 17, 2017 Posted September 17, 2017 Is your broken device' items live and synced (You can see thru your Loyverse' Back office items)? If yes, then once logged in to a new device, you'll be able to see all your items from your previous device.
Solution Robert Posted September 17, 2017 Solution Posted September 17, 2017 Yes every POS share the same item list, there is no need to copy items or anything similar. I guess you need to know how to add a new POS, you can find out here: https://help.loyverse.com/help/how-create-activate-and-delete-pos If you want to keep using the same POS as always, first you need to log out from the POS app in your device to be able to log in the app using a different device. Do I make sense? But I guess that if your device is broken you can't enter the app and log out... or can you?
