Does Loyverse have a trial period?
Go to solution Solved by Rodrigo Díaz,
Does Loyverse have a trial period mines says Trial ended on 31 Mar 18. Refuses to generate sales reports am a frantic please asset.
Have the same issue. Once the trial period expires, only you can still use the apps. However no more possible to create employees or POS or Sites.
Adding Employees and using Advanced Inventory are paid features.
To use them you have a 14 day free trial period.
After the trial ends you have to activate the subscription or unsubscribe.
After tou perform one of this actions you will regain access to the back Office.
If you are an old user, you were using the employees for free all this time. That's why it may have been a bit confusing. Now employees became a paid feature, that's why you need to make a decision.
Loyverse is still free if you don't use the employees.
I would recommend you to contact the Loyverse team directly, they will be able to help you out and find the right solution.
They are always available at the live chat at the website or from the app.
And, you are still generating sales reports, you can keep making sales, no worries, you are just having restricted access to the reports until you resolve the subscription.
I hope that was helpful.
