Which CCTV system is better to buy for small coffee shop?
Please recommend me which CCTV is better in quality-price ratio.
  • 1 month later...
Do you want to use closed-circuit television (CCTV) for surveillance purpose in the coffee shop? If so, I would recommend starting from the cheapest staff. For example, you can get an online camera which is storing records in the clouds. Then, after you use this simple solution, for a while, you can better understand your real needs. And you can upgrade to more complicated and expencive solution.
The one which is cheap enough and at the same time - reliable enough, do not be easily broken.
