Jack CHK Posted March 16, 2018 Posted March 16, 2018 How do I create a pos network: Samsung tablet, a scanner, thermal printer & cash drawer using a wifi or Bluetooth connection?
Hänsel Posted March 17, 2018 Posted March 17, 2018 To do this, go to the Android device's bluetooth settings and connect the printer and scanner. If your tablet supports OTG, you can connect a printer or scanner through the USB interface. To check if your tablet is supported OTG, download the 'OTG Checker' application from the Google Play Market. After that, you will have to set up the printer in the Loyverse POS app settings. The scanner will be ready for operation without additional settings. Most printers support the Cash Drawer. How to connect devices you can find in the Loyverse Help Center in the 'Hardware' section.
Solution ink Posted March 5, 2020 Solution Posted March 5, 2020 Here is the video about how to connect Bluetooth printer to the Loyverse POS.
