Tony O Posted February 14, 2018 Posted February 14, 2018 I want to give 10 points to all new subscribers as a one off. When I insert 10.00 it turns out 1000 points. Can you help?
Solution Teddy Posted September 20, 2019 Solution Posted September 20, 2019 Hi! You can export the list of your customers, add new customers, and add loyalty points then export it back into the Back Office.
Blinken Posted June 10, 2022 Posted June 10, 2022 I usually just edit their point balance in my Back Office.
