May 16May 16 I have an Android handheld POS terminal with a built-in barcode scanner. However, I am unable to enable the built-in barcode scanner to read product codes in Loyverse POS. An external barcode scanner connected via Bluetooth works fine. Is the built-in barcode scanner incompatible?
May 17May 17 Hello @LENVII We don't have official support for the built-in barcode scanner. But you may use the device's camera as a barcode reader. https://help.loyverse.com/help/barcodes-scanning-built-device
