jeronimovillora Posted January 9, 2025 Posted January 9, 2025 Me gustaria saber si el SUNMI D3 MINI 2,4", Chip, CD, Escáner (2D), USB, BT (BLE, 5.0), Ethernet, WLAN, es compatible con Loyverse Un saludo
Yasuaki Posted March 3, 2025 Posted March 3, 2025 Hello. If it has Android 5+, it should be able to run the Loyverse POS app on it. Meanwhile, the small screen is not supported. 1
jeronimovillora Posted March 30, 2025 Author Posted March 30, 2025 On 3/3/2025 at 11:59 AM, Yasuaki said: OK, Thanks
