How can i handle Deposit for Bottles and Cups?
Go to solution Solved by Sam2019,
Is anyone aware of a way to add the state required bottle deposit to the beverages that require it by law?
Hello! Without handling deposits for bottles and cups the most bars and clubs cannot use your software. is there a function which make this possible? Why i can not add a product with a negative amount? that would be a very easy solution to give the costumer back the deposit. can you hep with this problem? is there maybe another solution?
As I understood, it looks that at the moment there are not such options on Loyverse for deposits bottles
  • 1 month later...
I use the Cash Management function under the Shift option to do refunds without receipts, could be used to return deposits. The refunds are included on the Z1 report and Expected Cash, when the Shift is closed
