Title: MHT-P8001 Bluetooth printer does not print the date/time on the first receipt
I am using Loyverse POS on Android with an MHT-P8001 Bluetooth thermal printer.
I have a problem with receipt printing.
The first receipt prints correctly, but the date and time are missing. When I print the second receipt, the date and time of the previous receipt appear at the top.
This issue happens repeatedly:
Receipt #1 → No date/time.
Receipt #2 → Shows the date/time that belongs to Receipt #1.
Receipt #3 → Shows the date/time that belongs to Receipt #2.
I have already removed and re-added the printer and reconnected it via Bluetooth, but the problem still exists.
Is this a known compatibility issue with the MHT-P8001 printer, or is there any setting or firmware update that can fix it?
Thank you.
Please, try to follow these instructions:
Please go to the App → Settings → choose your printer, then open Advanced Settings → and in the field 'Cutter ESC/POS Commands', add 0A,0A before existing values. (This will make the printer feed more paper at the end of the receipt.)
For example:
You would have to write 0А,0А,1D,56,42,00
Once you've saved the changes, print a test receipt to verify the output.
ابغى باروكود في الفاتوره
