April 16Apr 16 Good afternoon, I've 3 POS working with Loyverse. The first one has works with an Android tablet an a Epson TM-M30 III printer connected with bluetooth. It works fine. So I've replicate the configuration in 2 others shops. In this case the TM-M30 III (same model but not buy at the same time), do not print from Loyverse but print from other app. If i try with the first printer in the new shops, it works. I've tried to solve the problem with Epson, they said that the problem is Loyverse not the printer. Someone has an idea to help me? François
May 11May 11 Hello @Francois Thank you for reporting the issue. Could you try updating all printers' firmware by using the EPSON TM utility app? If it doesn't solve the issue, could you take a video of the issue and send it to me? Best regards,
June 16Jun 16 Author Hello, Sorry, i've missed pour post. I've already tried to update the firmware to the last version, but it doesn't solved the problem. I'll take a video of the problem and i will send it to you Thanks for your help Edited June 16Jun 16 by Francois
September 3Sep 3 Hi I‘ve the same problem and I need asap a solution. Our big Event ist tomorrow. Is there a solution? Best regards Nikola
