Trouble shooting setting up a WiFi printer
cafe
Go to solution Solved by Andrew de Freitas,
You will need to know that IP address that was set.
It has to be in the same subnet (IP Range) as your network otherwise it won't be able to communicate with the rest of the equipment.
What brand is it? Some manufacturers have an app you can download to find and reconfigure the printers.
