Language problem on CVS
GeekStar
 Share
Hi, I export "sales by item" for stock sales by time and date.
I cannot see Korean langauage on CVS file.
I tried to encode UTF-8 in tools option in save as.
But still it does not change back to korean.
I can see the korean language on website. Not on CVS file and even I tried to encode to UTF-8, it does not change.
Can you help?
I tired google spreadsheet and excel 2007 and Excel365
In these kinds of cases, may I ask that you try to follow this guide provided on how to open the csv file in google sheet please? And in this guide, please note to remove the "Convert Text to numbers, dates, and formulas". This should allow you to display the texts of the csv file as is without the program automatically changing it for you:
Here is the link to the guide as well: https://help.loyverse.com/help/how-open-csv-file-google-sheets
It should be possible to do so if you follow this guide provided: https://help.loyverse.com/help/export-excels but based on my experience of using excel, there's always a chance where the program will automatically change data when you even did not want to so. If this did not work, I'd suggest sticking to Google Sheets.
 Share
