rhenfall Posted June 12 Share Posted June 12 Is there a way to use loyverse app without a pin? The fact is, it is time consuming effort, it always ask for a pin every time i exit or leave the app for a while. Previous version is better. It should have an option witgout using a pin for single employee. Link to comment Share on other sites More sharing options...
Angelika Posted June 13 Share Posted June 13 Hello! The PIN code is unigue for each employee and used for identification purpose. Unfortunately, if you are using the Employee Management and have at least one employee added in your back office, the PIN code is obligatory for each employee. Link to comment Share on other sites More sharing options...
rhenfall Posted June 13 Author Share Posted June 13 Im the owner and im the employee also, is ther away to turn the pin off? Link to comment Share on other sites More sharing options...
Angelika Posted June 13 Share Posted June 13 Hello Yes, you can do it by opening the owner card in the back office -> disable PIN code: Link to comment Share on other sites More sharing options...
rhenfall Posted June 13 Author Share Posted June 13 Yes i can disable it bilut i cant login without a pin Link to comment Share on other sites More sharing options...
rhenfall Posted June 13 Author Share Posted June 13 It worked now when i deleted other stores. Tnanks. Link to comment Share on other sites More sharing options...
