AFW Posted May 31, 2021 Share Posted May 31, 2021 I'm wondering if there is a way to not have to enter my PIN every time I change between apps or my display goes off. I keep the app open, but have to keep entering it over and over. It may be an easy fix, but I cannot find it anywhere. Link to comment Share on other sites More sharing options...
Christine Posted June 2, 2021 Share Posted June 2, 2021 Hello! You can disable PIN code only when you do not have any employees. To do that, please go to back office > Employee section > Employee list > Select owner > Scroll down and tap "DISABLE PIN CODE". Link to comment Share on other sites More sharing options...
