Geoffrey Posted August 22, 2020 Share Posted August 22, 2020 I've made my Worldpay account as Belgian user. I would like to connect it to Loyverse but I can't select 'Worldpay' in the list of payment options, only Sumup appears (but is way too expensive of course). How can I add the plugin for Worldpay to connect it to Loyverse so that it's connected to my register? Thank you. Link to comment Share on other sites More sharing options...
Solution Mag Posted August 22, 2020 Solution Share Posted August 22, 2020 Hi!Loyverse POS merchants can accept credit card payments via Worldpay in the USA only. So, you will be able to select Wordpay payment type, if you indicate United States as the country of registration, when you create Loyverse account Link to comment Share on other sites More sharing options...
Geoffrey Posted August 23, 2020 Author Share Posted August 23, 2020 19 hours ago, Mag said: Hi!Loyverse POS merchants can accept credit card payments via Worldpay in the USA only. So, you will be able to select Wordpay payment type, if you indicate United States as the country of registration, when you create Loyverse account Dear Mag, thank you for the reply. I already have an account, can I still change it somewhere or do i need to make a new one? Thanks Geoffrey Link to comment Share on other sites More sharing options...
Mag Posted August 23, 2020 Share Posted August 23, 2020 Please write request to change country of registration to USA to help@loyverse.com. You need to send this email from Loyverse account owner email address and indicate that the goal is Worldpay payment system there Link to comment Share on other sites More sharing options...
KevinS Posted April 25, 2021 Share Posted April 25, 2021 Not sure registering as United States is the correct way to integrate my payments? Are you considering this as an option? Thanks Link to comment Share on other sites More sharing options...
