Adnan Posted September 25, 2017 Share Posted September 25, 2017 In the items name in the CSV file, the items are written and saved in Arabic fonts. Upon importing the CSV file, all Arabic letters are transferred to "?" mark. I tried modifying the imported items by directly writing the item name in Arabic font, and it excepts. Nevertheless, the list of items is too large to do modifications one by one. Pls support to fix this import problem Link to comment Share on other sites More sharing options...
KHZ Posted October 7, 2017 Share Posted October 7, 2017 You need to open excel program first, then click Data, from Text. A window will open to select your CSV file. After you select it, another window called Text Import Wizard will open. Follow the Three Steps that apear. The first step Choose the File Type that best describes your data (select Delimited). You may start import at row 2 as row 1 is too large and contains names of each coloum which you may not need. File Origin select 65001 unicode (UTF-8). Then go to next step Delimiters, select Comma only. Then next and finish. Link to comment Share on other sites More sharing options...
