  • 0
Sign in to follow this
championv
Print labels for display stands
Question
championv
It seems the labels by Loyverse are a kind of tag. Can I print labels for display stands?
Share this post
Link to post
1 answer to this question
  • 0
Theodore
I suggest you try to choose most appropriate label type for your stand and select checkboxes only for the name of item and price (for barcode select 'none'). And print it on office A4 printer and paper and cut it.
Will this solution acceptable in your case, or do you need something special?
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Sign in
Already have an account? Sign in here.
