Print Logo on Till receipt (SBV-80B-USEWB Multi Interface Receipt Printer)
Hi all,
I am using Android.
I have found that I can print the logo stored in my printer using the ESC/POS commands 1C 70 01 00
I have the SBV-80B-USEWB Multi Interface Receipt Printer (generic Bluetooth/wifi/LAN/USB/COM): https://store.varlink.co.uk/SBV-80B-USEWB_80mm_Thermal_Printer_[UK]__48512.html
I have selected Other Model, Bluetooth 80mm printer. (it is listed as KP80)
In the Advanced section for the printer, (Settings | Printer model | Advanced Settings, add the following into the Initial ESC/POS commands box:
1C,70,01,00
You will have already uploaded your logo to the printer using the supplied software from the printer manufacturer.  Remember that it is black and white.
Of course, I am sure that you could print your logo at the bottom of the printer if you added those commands just before the cutter commands on that screen (Just tried it - it works..)
Have fun
Answers
Now Android POS can print logo on the receipts more simple way. For this, you need to add the logo in receipt settings in the Back Office.
Details: https://help.loyverse.com/help/how-add-logo-receipts
Thanks for the valuable experience! Is it possible to know  in more details how you did it?
I'm afraid there aren't any further instructions I can think of. Put your logo into the printer using the instructions from your own printer then do as described in my post.
That's all
Votes 0
Thank you for sharing your experience with SBV-80B-USEWB receipt printer. It would be useful to know, does this printer work well with Loyverse POS? Without any problems?
Votes 0
Loyverse.town uses cookies. By continuing to browse the site you are agreeing to our cookies policy. Learn more Ok
