How to use cash drawer with Dejavoo z series CC machine
Vibhor.verma
Go to solution Solved by Peter,
I have a dejavoo cc machine with inbuilt printer from vantiv. How do i connect my cash register with ipad so it works fine and I dont have to buy a receipt printer since my receipts are printed with the cc machine.
  • 3 weeks later...
I'm not sure Loyverse app can print receipts using the inbuilt printer but I don't own a dejavoo machine. The Loyverse app may not be compatible with any machine, you should check with Vantiv staff or Loyverse staff whether your machine is compatible.
