How to connect printer using Bluetooth?
Jack CHK
Go to solution Solved by ink,
How do I create a pos network: Samsung tablet, a scanner, thermal printer & cash drawer using a wifi or Bluetooth connection?
To do this, go to the Android device's bluetooth settings and connect the printer and scanner. If your tablet supports OTG, you can connect a printer or scanner through the USB interface. To check if your tablet is supported OTG, download the 'OTG Checker' application from the Google Play Market.
After that, you will have to set up the printer in the Loyverse POS app settings.
The scanner will be ready for operation without additional settings.
Most printers support the Cash Drawer.
How to connect devices you can find in the Loyverse Help Center in the 'Hardware' section.
